RadioBOSS Cloud
What is RadioBOSS Cloud: https://www.radioboss.fm/radioboss-cloud/
We're open to any suggestions, feature requests, bug reports!
Previous topic about RadioBOSS Cloud (beta): https://www.djsoft.net/community/threads/radioboss-cloud-beta.5593/
RadioBOSS Cloud 1.0
What's new
  • Added Spanish, German and Russian localizations
  • Added Podcast playback support
  • Shows the total number of uploaded tracks in Media section
  • Fixed "Reindex tracks" feature
  • Fixed performance issues in the Overview tab
  • Fixed occasional errors on downloading files
  • Fixed issues in API commands
  • Fixed FTP file locking issue
The problem of blocking files still continues, some files and folders do not delete, this occurs on the C2 server and due to the fatality that occurred in the last few days I asked for a new account, this occurs on the C15 as well.
RadioBOSS Cloud 1.0
What's new
Need The Repeat Protection to be stable please. Getting complaints from listeners saying the same song is getting repeated closely
Can you please provide some details on how you use it, so we can try doing the same and get the locking issue? Also, do you have any connectivity problems? For instance, if you download a file via FTP and the connection is blocked, it can stay locked for some time.
C2 is down... Fix it as soon as possible please.
We're working on it. It's not really possible to fix - we'll just order a new server and load a backup to it. Building a server takes time, it should be ready within couple of days.
RadioBOSS Cloud 1.1
Changes
  • Improved reporting performance
  • connect/disconnect commands can be used in the scheduler
  • Reduced occasional appearance of Timeout and E0 errors
  • Fixed: current listeners list was empty for some streaming accounts
  • Fixed: help/quick start links do not work
  • Improved track list selection quality and diagnostics
Using connect and disconnect commands
  • Use connect or disconnect in the scheduled event to turn streaming on/off completely
  • Use connect N or disconnect N to control a specific encoder; N = 1 is the RadioBOSS Clous own connection to the server, N = 2 and up is Additional Encoders (2 - first encoder, 3 - second encoder etc).
RadioBOSS Cloud update
An update was released to fix the repeat protection not working bug on certain streaming accounts.
Hope this helps just put this together real quick
If you need more help message me
SOME THINGS YOU WILL NEED IN ORDER TO CONNECT TO A SERVER USING ADDITIONAL ENCODERS
TYPE = SHOUTCAST, SHOUTCAST 2, ICECAST
SERVER ADDRESS =
PORT
PASSWORD
FROM THE OVERVIEW
click on setting A
from the tab menu cick on streaming B
scrool down to Additinal encoders
(IF YOU HAVE NOT SETUP ONE BEFORE THE YOU WILL NEED TO CLICK c
If you have setup before then click on EDIT D
when the box opens
Enabled DO NOT CHECK MARK IT Z
Use the drop down Type E to select server type
Server address F type in the server address
(BE CAFEUL THIS IS ONE PLACE MISTAKES ARE MADE AND YOU CAN'T CONNECT)
Port number type the port number they gave you
Type in password they gave you G
Display name type in the name of you show (THIS MAKES IT EASY TO FIND LATER ON)
Then Click OK
the box will close
at the bottom of the page click SAVE
now click on Scheduler tab at the right menu M
cLCIK add butt
On the select DON'T CLICK type in connect 2
on the Title p
type in the name of connect to station
under start Q
set the time you want the broadcast to start
on week days check mark the days you want the stream to run
under
insert type R select which action you want
clck ok S
NOW YOU NEED TO CREATE A STOP FOR THE BROADCAST STREAM
CLICK ADD FROM THE SCHEDUE
UNDER ACTION TYPE O
disconnect 2
Title
discont from station name
Under start time Q
which will be the time you want to STOP the stream
Days of the week to stop the broast stream
insert type leave as is
click OK
SERVER ADDRESS =
PORT
PASSWORD
FROM THE OVERVIEW
click on setting A
when the box opens
Then Click OK
the box will close
cLCIK add butt
on the Title p
under start Q
under
clck ok S
UNDER ACTION TYPE O
disconnect 2
Title
Under start time Q
click OK
Thank you very much.
Hi, I would like to report that for the past 2 days, my station has been encountering problems airing events as scheduled.
This bug started to happen after 8am (UTC+8 Singapore time) each day, where the timing of the events (under Upcoming Events on the Overview page) keep getting pushed forward and never get aired.
I have to go to System and click Restart player for these past 2 days, to reset the playback & for the Upcoming Events to show the correct timings and air on time.
Can you look into this issue? It has not happened in the past until 2 days ago. No changes have been made to the event timings in the Scheduler.
I have attached screenshots of the bug. Thank you.
I too have noticed a problem, scheduled connect and disconnects not happening. Ive double checked everything and it still sometimes fails.
It appears that it somehow failed to correctly apply the time zone configuration. Does it work properly now or the problem still there?
Can you please specify the account user name to check and what events do not run? Do they run now or it still fails?
