I. Setting up Live broadcast1)
Login to Live365 broadcast control panel
2)
Select broadcast's format: click My Profile, and select the desired format in the drop-down box (pic. 1).
3)
Switch broadcast mode to Live: click Controls and then "Switch broadcast mode" button. Check "Live" and click "Save" button. The next screen will give server connection details (pic. 2) - you'll need it in the next step.
4) Run RadioBOSS, open Settings->Broadcast. Click "+", add server address from Step 3, enter password for your Live365 account in the Password field. Select the format to the same selected in the Live365 control panel on step 2. Note that MP3 and MP3 pro are not the same. (pic. 3).
5) Click "OK" and check the checkbox in the list to enable this server. Also check the "Broadcasting Enabled" option above. Click OK.
II. Sending song titleIn the Settings window, click "Log files (Reports)", enable HTTP Get request. In the URL put the following string:
http://tools.live365.com/cgi-bin/add_song.cgi?version=2&pass=MYPASSWORD&handle=MYLOGIN&title=%title&artist=%artist&album=%album
Note: change MYPASSWORD and MYLOGIN to your Live365 login/password. (see pic. 4).
Note: if your RadioBOSS version is 4.4 or prior, you'll need to download the "bassenc.zip" file (attached to this post) and unpack it to RadioBOSS directory (ask "Yes" when it asks about file overwrite; RadioBOSS have to be closed during this).
