RadioBOSS
Read MoreDownloadBuy Now
Author Topic: in-bulit broadcasting problem  (Read 366 times)
bobby
    • View Profile
« on: January 12, 2012, 04:39:00 PM »
Hey djsoft
on the newer release of radioboss, it won't allow me to broadcast my music over on any of my streams at all
so can you guys fix this by next week please
thanks
bobby
    • View Profile
Re: in-bulit broadcasting problem
« Reply #1 on: January 13, 2012, 04:21:08 AM »
Hey staff
This newer version of radioboss won't connect at all on my icecast .ogg server anymore period and it won't connect to icecast .mp3 servers at all either
it just stays at prebuffering 0% forever
and the new song title appearing right away feature is kinda of broken on icecast servers
so can you guys fix this problem today please
thanks
« Last Edit: January 13, 2012, 08:29:34 AM by bobby »
  • Administrator
    • View Profile
    • http://www.djsoft.net
« Reply #2 on: January 13, 2012, 08:54:14 AM »
Are you trying to broadcast or to play internet streams?
bobby
    • View Profile
« Reply #3 on: January 13, 2012, 08:56:45 AM »
Hey djsoft
I am try to play music from my radioboss to my icecast .mp3 and .ogg servers
but it just stays at 0% prebuffering all day and night
it works fine when you people do not play the music first before they connect to there icecast servers
but when you play the music first it gets stuck at 0% prebuffering
bobby
    • View Profile
« Reply #4 on: January 14, 2012, 05:58:24 AM »
Hey staff
is this icecast connect feature going to be fixed on the next version of radioboss
  • Administrator
    • View Profile
« Reply #5 on: January 14, 2012, 06:07:47 AM »
I don't see any problems with Icecast or Shoutcast connections...
You can try any of the previous versions if the latest one doesn't work for you:
http://dl2.djsoft.net/radioboss_setup_4.6.3.905a.exe
http://dl2.djsoft.net/radioboss_setup_4.6.2.902.exe
http://dl2.djsoft.net/radioboss_setup_4.6.1.898.exe
http://dl2.djsoft.net/radioboss_setup_4.6.0.895.exe
bobby
    • View Profile
« Reply #6 on: January 14, 2012, 06:46:57 AM »
Hey djsoft
here is a screenshot of the icecast connecting problems
thanks
and if you disconnect the icecast connection and reconnected it, it gets stuck at 0% prebuffering and i have to start the file over again
« Last Edit: January 14, 2012, 06:54:51 AM by bobby »
  • Administrator
    • View Profile
« Reply #7 on: January 14, 2012, 06:58:23 AM »
This can happen if you incorrectly set up the broadcasting.
For OGG streams, you should use the mount point which ends in ".ogg", eg in the Encoder settings, in the server field enter something like this:
myserver.com:8888/mystream.ogg
bobby
    • View Profile
« Reply #8 on: January 14, 2012, 07:02:44 AM »
Hey djsoft
everything is setup correctly setup on my icecast encoder setup
take a look at this new screenshot please
thanks
bobby
    • View Profile
« Reply #9 on: January 14, 2012, 07:07:20 AM »
no believe me that the icecast connections are not working on radioboss anymore at all
  • Administrator
    • View Profile
« Reply #10 on: January 14, 2012, 08:39:46 AM »
Can you please download the previous version (links above) and check if it's working?
It could be something wrong in Winamp or on your broadcasting server...
bobby
    • View Profile
« Reply #11 on: January 14, 2012, 08:42:36 AM »
Hey djsoft
I downloaded the previous version a few days ago and my icecast server connected just fine on the previous versions
so what could be wrong on this newer version of radioboss then
bobby
    • View Profile
« Reply #12 on: January 14, 2012, 02:44:07 PM »
Hey staff
did you guys get my latest email message yet just curious
thanks
  • Administrator
    • View Profile
« Reply #13 on: January 14, 2012, 03:14:56 PM »
Yes, it's already in the bug list. Thank you for reporting!
bobby
    • View Profile
« Reply #14 on: January 16, 2012, 04:28:44 PM »
Hey djsoft
how much longer until my icecast problem is fixed
thanks
Verification:
