RadioBOSS
Read MoreDownloadBuy Now
Author Topic: Adding Comment to Songs  (Read 2576 times)
radyofog
    • View Profile
« on: November 11, 2009, 04:33:12 AM »
Hi. Im trying to divide times acoording to genres. I read a post about this in this form. I applied it but when Im adding comment to songs (by selecting all and apply) the id tags of songs dissappear.
Can you tell me why this happens. Or I should do one bye one this operation.
  • Administrator
    • View Profile
    • http://www.djsoft.net
Re: Adding Comment to Songs
« Reply #1 on: November 11, 2009, 06:16:57 AM »
Hello!
Which version of RadioBOSS do you use?
radyofog
    • View Profile
« Reply #2 on: November 11, 2009, 07:18:15 AM »
Hi Im using 3.0.0.350
  • Administrator
    • View Profile
« Reply #3 on: November 11, 2009, 07:25:07 AM »
Hello!
Thank you for report! We confirmed this bug, and it'll be fixed later today. It exists in the latest version 4.0 also.
I'll post here an update when it's done.
radyofog
    • View Profile
« Reply #4 on: November 11, 2009, 07:29:49 AM »
Thanks a lot for you attention
  • Administrator
    • View Profile
« Reply #5 on: November 11, 2009, 10:23:15 AM »
Hello!
The update is ready (fixed mass tag edit in the Music Library, also some small fixes with ID3v2/v1 tag save).
You can get update here: http://www.djsoft.net/enu/update.htm
radyofog
    • View Profile
« Reply #6 on: November 11, 2009, 11:08:44 AM »
thank you very much  ::)
James Totton
    • View Profile
Re: Adding Comment to Songs and ID3 tag issues
« Reply #7 on: December 03, 2009, 10:20:01 PM »
Yes, thank you for fixing up this bug. It was worrying me too  :)
One thing I discovered this morning re editing tags in the Music Library - if the song has an ID3 v1 tag, you may have problems with genre names. There are only a limited number of music genres a v1 tag can handle (the prescribed ones from the list). I had to use a free programme called MP3 Tag Editor to change the tag to v2. Then I was able to choose any genre name that I like.
I guess the moral of the story is...try to make sure your music files all have v2 tags. Then - no problems at all :)
If I am not entirely correct with this observation, perhaps our friendly moderator can correct me.
Thanks very much
  • Administrator
    • View Profile
« Reply #8 on: December 04, 2009, 05:09:46 AM »
Will be fixed in the next version. It'll work like this: program reads whatever tag (v1/v2/ape) mp3 file has, and save it using ID3v2.
Verification:
