RadioBOSS
Read MoreDownloadBuy Now
Author Topic: Schedule option  (Read 3962 times)
bylove
    • View Profile
Schedule option
« on: January 19, 2010, 04:50:52 AM »
Hi,
I use RadioBoss demo software
How to do add schedule program after 10 minutes stop.
Note : I know mid-level English
thanks
  • Administrator
    • View Profile
    • http://www.djsoft.net
Re: Schedule option
« Reply #1 on: January 19, 2010, 05:34:44 AM »
Hello!
You mean, after you click "Stop" button, something (playlist) should be started after 10 minutes?
If yes, it's possible, in the menu, click "Settings"->"Silence Detector", set "Length of silence" to 10 minutes, check "Load auxiliary playlist" and in the field below, enter playlist filename.
Thank you!
bylove
    • View Profile
Re: Schedule option
« Reply #2 on: January 19, 2010, 09:35:07 AM »
Schedule add
file: c:\test.mp3 (length 04:20)
next song playing after 04:20
yes running
also
url : http://sample.com/listen.pls  (length ??:??)
next song or url play after 10 minutes not running
  • Administrator
    • View Profile
Re: Schedule option
« Reply #3 on: January 20, 2010, 04:53:15 PM »
If you place an URL to the playlist, it'll play endlessly, until something else is started by user or scheduler.
Please describe in more details what are you trying to achieve.
bylove
    • View Profile
Re: Schedule option
« Reply #4 on: January 29, 2010, 05:09:15 AM »
Connect to other streams
Sample : There are broadcast live games this evening
I want to make a connection to joint publications
thanks
  • Administrator
    • View Profile
Re: Schedule option
« Reply #5 on: February 05, 2010, 01:33:14 PM »
Sorry for a long delay.
You can play streams by scheduler (please make sure you're using the latest version - RadioBOSS 4.0.3.449, there were some issues fixed relating streams playback).
If you want to play stream for some time, and then play song in your playlist, you should add two tasks to the scheduler.
First: in the filename enter stream URL (http://...), enter date/time when you need it to start. For example, you set it to run at 12.00.
Second: in the filename field you enter word next and set its time to, for example, 12.10.
In result, the stream will play for 10 minutes, and then next track from your playlist will start.
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #6 on: February 07, 2010, 09:04:38 PM »
I set up the schedule to play as you said,and it works,but it stacks up other scheduled events,such as commercials,and plays them all when playlist resumes using NEXT. Can we add a time limit to these items so if they cant play due to a long stream program,they will automatically be discarded??? Maybe a box to put the time to wait before discarding it would be nice. This could also serve as a duration time for streams to eliminate the need for a second entry of NEXT.
  • Administrator
    • View Profile
Re: Schedule option
« Reply #7 on: February 08, 2010, 05:42:18 AM »
You can use the "Remove previous schedule from the playlist" option to avoid stacking (this will work in case when commercials launch before the stream).
If commercial are added when stream is already playing, then, instead of NEXT command, you can start any MP3 file (jingle?), with "Remove previous schedule" and "Run scheduled launch without waiting" flags - this should do the thing.
About streams duration, this feature will be added in the next minor update, within 10 days. Also, we'll think about some kind of expiration for scheduled tracks.
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #8 on: February 09, 2010, 06:53:07 PM »
The remove previous schedule doesnt work right. It seems to add scheduled items to the playlist instead. It added so many items that it froze up today,no errors were showing,but it would not play anything. I had to re-boot the computer and rebuild the playlist. Not good!
  • Administrator
    • View Profile
Re: Schedule option
« Reply #9 on: February 10, 2010, 05:54:16 AM »
Please describe your setup in details. It's hard to tell without the info.
The "remove previous schedule" option removes all tracks which were added by previous tasks and then adds new track/playlist, which is specified in the "Filename" field.
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #10 on: February 10, 2010, 10:21:01 PM »
New problem,since updated version was installed,when trying to play a daily scheduled stream,the following errors occured:
access violation 007C8A20 in module radioboss.exe,read of address 00000084
access violation 007C899B in module radioboss.exe,read of address 00000070
log entry unable to play,invalid handle
After this failed,I selected the file and clicked run now and it worked.
The schedule file contains only the http address and checked the box run scheduled launch without waiting
  • Administrator
    • View Profile
Re: Schedule option
« Reply #11 on: February 11, 2010, 06:33:23 AM »
Does this error occur every time the scheduled event is started, or error is random?
I just tried to reproduce this, but no success. Could you please send stream address you're using to support@djsoft.net so we could check.
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #12 on: February 11, 2010, 10:35:02 PM »
It occurs at the scheduled time,throws the error windows. I can tell it to run now and it works fine,but the schedule bombs every time. I think I know why,in the playlist,it says buffer 58%,then it tries to play another file with the same exact start time. I have fixed this mistake and will see if it works.
  • Administrator
    • View Profile
Re: Schedule option
« Reply #13 on: February 12, 2010, 10:29:23 AM »
Thank you for explanation!
Yes, this looks like a problem. If you start another file when network stream buffering is not completed, sometimes it shows an error. Will be fixed soon.
And, why it's needed to start 2 files at the same time?
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #14 on: February 12, 2010, 07:25:56 PM »
Well,it was my mistake to have two starting at the same time,its fixed now! The program should have discarded the stream and played the next instead of hanging up.
It still does funny things when I use the REMOVE PREVIOUS SCHEDULE option. It caused the program to freeze hours later with no error message again,it also put 30 or 40 scheduled files in a row into the playlist when they should have been spread out over the hours. What am I doing wrong here?
 Play ABOVE THE AIR also locks up the program,reboot needed.
I think the whole playlist and scheduler needs a makeover into something more stable and user friendly,IMHO.
My old program was super in the scheduling and playlist,but had no eq,streaming or plugin options.
Verification:
