RadioBOSS
Read MoreDownloadBuy Now
Author Topic: Schedule option  (Read 3982 times)
  • Administrator
    • View Profile
    • http://www.djsoft.net
Re: Schedule option
« Reply #15 on: February 12, 2010, 08:00:14 PM »
Well,it was my mistake to have two starting at the same time,its fixed now! The program should have discarded the stream and played the next instead of hanging up.
Yes, the stream playback will be fixed in the next update. As well as whole audio engine will be improved.
I think the whole playlist and scheduler needs a makeover into something more stable and user friendly,IMHO.
My old program was super in the scheduling and playlist,but had no eq,streaming or plugin options.
That's what we're working on now. But, the errors you describe (like inserting one file many times into the playlist) - were fixed versions ago. Please check if you're using the latest version.
About freezes, it shouldn't happen. Why are you sure that "Remove previous schedule" option does this?
Also, "play above the air". Does it freeze every time started, and, does it happen if you click the "Run Now" button?
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #16 on: February 12, 2010, 08:42:36 PM »
Here it is laid out for you,I took all the extra programs out,no streaming,no plugins and this program cant run 24 hours without freezing my computers. They are plenty big enough,Compaq 2.3 gig,1gig RAM,1terabite of HDD and has run Zara with Winamp and Shoutcast for more than a year without a crash. I do not understand how the playlist and scheduler are supposed to work,they dont do what they say,it does not handle errors well,it crashes or freezes up. You have a very good player and eq,the streamer works well but the rest left me disappointed. So,sad to say, I will request a refund and go back to Zara Radio and Winamp as I have now lost my advertisers and audience. I hope you are able to resolve all the issues,if you do,I will try it again.   Good luck!
  • Administrator
    • View Profile
Re: Schedule option
« Reply #17 on: February 13, 2010, 06:50:09 AM »
Your order was refunded, thank you for using! But, I'm pretty sure that it's something wrong with your computer and/or OS (also, according to this thread: http://www.djsoft.net/smf/index.php/topic,593.msg2838.html#msg2838).
This program has many users, and almost all of them are using scheduler - but we receive no reports about freezes or something like this.
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #18 on: February 13, 2010, 09:06:39 AM »
I tried to make Radiboss work on two different computers,both more than the minimum requirement and way beyond. I went as far as wiping out the hard drive completely,reinstalling XP PRO,having a Microsoft certified technician certify and benchmark the computer,reinstalled Radioboss latest version. I dont know what else was humanly possible on my part. I appreciate your effort to help and the refund.
  • Administrator
    • View Profile
Re: Schedule option
« Reply #19 on: February 13, 2010, 11:35:59 AM »
That may be a strange sort of incompatibility, and it'll take really much time to find out where the problem is. You can come back later and check how things are going :)
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #20 on: February 14, 2010, 10:23:53 PM »
Well,my computer pro friend and I were going over the problems and we found the latest version (457) to be the problem. It uses 50% more resources than the (453) version and just plain wont run right on any of the SEVEN computers we tested it on with streaming and plugins. (453) runs ok except for the funny playlist stuff of adding songs from nowhere and commercials stacking up. I will keep checking to see your progress in fixing all the bugs and features. I would love to see it work properly, I would certainly use it then.
  • Administrator
    • View Profile
Re: Schedule option
« Reply #21 on: February 15, 2010, 07:37:05 AM »
Thank you! For now we're rewriting all playback/scheduler/broadcasting related stuff from the scratch (it'll take about a month to implement, test, etc before it'll be released). I'm pretty sure that all bugs will be fixed after this (but, new bugs may be introduced :)).
WILCOM LABS
    • View Profile
Re: Schedule option
« Reply #22 on: February 15, 2010, 09:04:54 PM »
I can beta test if you like,let me know...
  • Administrator
    • View Profile
Re: Schedule option
« Reply #23 on: February 16, 2010, 08:22:40 AM »
I'll let you know when it's ready (2-3 weeks maybe).
Verification:
