RadioBOSS
Read MoreDownloadBuy Now
Author Topic: errors with playlists generation  (Read 3629 times)
0 Members and 2 Guests are viewing this topic.
KarlZ
    • View Profile
    • http://www.paris-one.com
Re: errors with playlists generation
« Reply #15 on: March 30, 2010, 11:20:19 AM »
It seems that the problem randomly happened.
I'm using the latest release of radioboss (4.1.0.483) and the problem happened very often.
Here's a sample of the report:
Quote
error;"Exception: Range check error. Func: GetHLItem [124, 124] Func: PlayNextTrack";
any idea on the reason why the playlist generator can't work?
do you need my config files? and wich ones?
Last time, I've noticed that radioboss use the itune tags for some tracks and not the ones I've saved, so I've delete unecesary tags from my files to see if it changes womething... wish it will work...
« Last Edit: March 30, 2010, 11:30:19 AM by KarlZ »
  • Administrator
    • View Profile
    • http://www.djsoft.net
« Reply #16 on: March 30, 2010, 02:12:50 PM »
When does this error happen? You write that problem with playlist generator, but this error comes from player.
RadioBOSS uses different tag storage format for different files, this is a standard behaviour, and shouldn't cause any problems.
KarlZ
    • View Profile
« Reply #17 on: March 30, 2010, 10:14:31 PM »
The error message came after the use of the generate function, and it also happened sometime when I try to generate manually a playlist.
The program doesn't answer, then after 1 or 2 minutes I have the message box "Error while creating playlist! (not enough tracks)"...
Verification:
