RadioBOSS
Read MoreDownloadBuy Now
Author Topic: Broadcasting Issues  (Read 2545 times)
z100internet
    • View Profile
Broadcasting Issues
« on: February 05, 2010, 07:26:34 PM »
I love this software...bought the full version but I am having issues connecting to my server. I have Live365...what exactly do I need to do to connect Radioboss to the Live365 website? I know how to run LIVE mode on 365 because I have done it with SAM. I believe I filled all my ID and Port numbers correctly. It stays active for a minute and then comes back as Connection/encoder died (output1) restarting...Cannot start broadcasting (output 1): Error-1. I have also seens Error code = 2
Please help!  ???
Thanks!!
  • Administrator
    • View Profile
    • http://www.djsoft.net
Re: Broadcasting Issues
« Reply #1 on: February 05, 2010, 08:42:44 PM »
Looks very strange. The 2 and -1 errors usually occur because of incorrect server or port, also, maybe some software (firewall/antivirus) blocking the connection - please check this.
You say that it disconnects after one minute: do you have any files played? (I'm sure you do, but just for sure...) Most servers will disconnect the source after 30 or 60 seconds if nothing is played.
Also, you may send us the data (server, port, password) to support@djsoft.net so we could check what's going wrong.
JavierV
    • View Profile
« Reply #2 on: March 27, 2010, 12:13:40 AM »
and....there solution to this problem? it was?  Thanks
  • Administrator
    • View Profile
« Reply #3 on: March 27, 2010, 05:16:43 AM »
Yes, the problem with broadcasting to Live365 servers was solved already.
JavierV
    • View Profile
« Reply #4 on: March 27, 2010, 09:02:47 AM »
I have a similar problem. Almost every 20 hours the signal is disconnected and I get the message: "Can not start broadcasting (output 1) error -1" then "Connection died encoded restarting output 1, this happens for 10 minutes, then returns to normal. The problem is that sometimes, at a time, playback fails because the music sounds stuck or scratched, and the indicator below the radio Boss: CPU Load 90% mark up. The company that provides streaming tells me that the problem is mine. It is software failure? I have a PC Intel Core 2 Duo 2.66 Ghz 4GB RAM Windows 7. Thanks
  • Administrator
    • View Profile
« Reply #5 on: March 27, 2010, 11:25:54 AM »
Are you using the latest version of RadioBOSS?
Verification:
