RadioBOSS
Read MoreDownloadBuy Now
Author Topic: radioboss 4.0.2.441 folder song cannot update  (Read 1018 times)
hartono chien
    • View Profile
« on: February 09, 2010, 02:22:50 AM »
but in old version radioboss 4.0.2.439  folder song after we put some song or add some song file automatic update
  • Administrator
    • View Profile
    • http://www.djsoft.net
Re: radioboss 4.0.2.441 folder song cannot update
« Reply #1 on: February 09, 2010, 06:35:17 AM »
You can click F5 to update folder contents.
Also, it updates automatically, but newly added files appear at the bottom of list (not sorted alphabetically).
« Last Edit: February 09, 2010, 07:51:29 AM by djsoft »
hartono chien
    • View Profile
« Reply #2 on: February 10, 2010, 02:05:48 AM »
yes i can update with F5  but in older version can update automaticly
the big question is , how can the new version more manual than old version
thank you
  • Administrator
    • View Profile
« Reply #3 on: February 10, 2010, 05:44:07 AM »
As I already said, it is not necessary to press F5 unless you need new files to be alphabetically sorted in the list. New files appear at the bottom. Please see the screenshots attached. On the first one, you see folder opened. Then, I add new file to this folder (using windows explorer), and you see that file appeared automatically on the second picture (but it's the last one displayed for this folder). No need to press F5.
Verification:
