RadioBOSS
Read MoreDownloadBuy Now
Author Topic: i need mic auto on  (Read 1056 times)
hartono chien
    • View Profile
i need mic auto on
« on: February 10, 2010, 01:59:15 AM »
i use radioboss for streaming,my problem if my electricity suddenly turn off my radiobos can auto reconect but for push the mic button i have to push manual,this computer get the source sound from another computer so have to push the mic button to send to streaming,
so i need after auto reconet plus auto on mic button
thank you
  • Administrator
    • View Profile
    • http://www.djsoft.net
Re: i need mic auto on
« Reply #1 on: February 10, 2010, 05:48:21 AM »
You should consider using the Line.In instead of MIC button. It works exactly the same way as Mic, but you can make it to play at program startup.
To add Line.In to the playlist, in the menu click Playlist->Add LINE.IN
Then, setup it in the settings (so it'll use the same input as MIC).
WILCOM LABS
    • View Profile
« Reply #2 on: February 11, 2010, 12:00:00 AM »
I would like to see the mic button have a hotkey and mic button on the main page instead of the fx page.
  • Administrator
    • View Profile
« Reply #3 on: February 11, 2010, 06:28:36 AM »
The MIC button is located in the toolbar, the most right. Hotkey for this is planned for next release.
Verification:
