How to enable "Stereo Mix" input in Windows Vista, Windows 7.
"Stereo Mix" is a special audio device in Windows 7 and Vista which allows to record everything what goes to the sound card output.
This is required if you want to record broadcast using RadioLogger (
http://www.djsoft.net/enu/radiologger_description.htm), or, if you broadcast with RadioCaster (
http://www.djsoft.net/smf/index.php/topic,848.0.html)
Solution, which works in most cases:
1. Click the Start Button, type "MMSYS.CPL" (without quotation marks) in the Start Search box and press Enter. Or, in the Control Panel open "Sound" applet.
2. On Recording tab, right-click on the blank area.
3. Check “Show Disabled Devices” and “Show Disconnected Devices” and the Stereo Mix should show up. If it is disabled, right click on it and choose Enable.
If the "Stereo Mix" still not there, you may have the "Wave Out", "What U hear" instead.
