beta 6.3.0.1
waynenrich
beta 6.3.0.1 there seems to be some conflict betweeen 6.2.42 and the 6.3.0.1 thay both freez and will not close now i have removed the 6.3.0.1 all seems to be fine again
it seems i can not run the beta on the same machine i used my subscription key no cracks other thaan that it ran well for 3 days
There can't be any conflict, all instances work independently of each other. The problem is somewhere else.
no its a confict because i uninstalled 6.3.0.1 and havent had a problem since it worked for three days
every instance of radioboss froze and wouldnt even let me close it in task manager
i am using windows server 2019
If the reason was RadioBOSS, it will usually create a bug report - you can send it to us from Help->Contact support->Send bug reports menu.
