Block songs by day and time
xzsaimon16
Hello how are you, I would like to know if there is an option to block songs, ids, jingles, sweepers, etc. per day.
That is to say, to be able to select which file should not sound, for example, at 5:00 p.m. on Fridays.
If there is no such option, could it be added?
It would be great to put it in the track tool as an option.
Something like "lock file for days and hours..."
In the screenshot a graphic example
After having published this post I realized that there is a request for the same option in another thread.
There is another feature that would be very nice to include and it would be that a "specific" ID - Jingle or Sweeper (not file type) is not selected or omitted according to the "tag" or the "genre" or "the year".
Example: "ID - new music" [omit for the Tag "Classical Music"]
Yes, this feature was requested couple of times and it should be implemented in the next major update.
brilliant!.
one question: is there a way or an app to edit events, edit the music database from another computer on the same network? something similar to jazler workstation?
This is not really possible with RadioBOSS currently. You can install RadioBOSS on another computer, create events, save them to the file, then copy this file to another computer - but it's not very convenient. We'll consider adding remote control feature in the future versions.
