Yes, this is the problem with buttons and with toolbar icons also (although those are starting to be visible when scale is 150% and more). There are currently technical reasons why raster icons are used instead of vector ones. The problem should be resolved in the next RadioBOSS 5.9 update.
By the way, the past RadioBOSS versions had much worse scaling support than the current - compared to those, "creepy" playback buttons are nothing
