Crossfade issue
While playing a playlist with about 500 songs, I notice that some songs, not all, aren't crossfading. They'll fade out completely before the next song starts. In the Crossfades settings I have the "Mix point" checked and set to 0.0 sec. and "Trigger mix set" at -20db. When the songs that do crossfade correctly, I notice the thin line appears in the "On Air" player which indicates where crossfade will occur. With songs that aren't crossfading the thin line does not appear. My settings allow a song that ends abruptly to immediately start the next song back to back. If the song has a fade out it will crossfade at the -20db point. Does this have something to do with some of my music files (mp3, flac, wav)? ???
This means when the song level is high, there will be non overlap. You should set Mix point to something larger than zero.
