default picture
Thanks for explaining. I have a problem with default pictures during the work. When I download a picture, its background turns black, and the pic looks awful. Can't say it's a huge problem that disturbs me from work, but I'm a perfectionist. So, it happens regardless of the format - I downloaded files in JPEG and PNG - still the same problem with the black background. I even worked with the background remover to fix the issue, but it seems that the problem is in the soft itself, not in the pic formats. So, should I reinstall the software or there's a patch to fix the issue? Thx.
The image must have square aspect ratio, otherwise it will be converted to square with rest of the space filled with black color.
