RadioBOSS doesn't drop the stream, if you see that the stream fails to play properly, the problem is either with the stream or with your internet connection.
It loads/plays fine but after 5-10 minutes it drops completely I have tried with both internal and external and both icecast and shoutcast incoming streams it still does it
AAC+ at 128kbps is not a problem, also RadioBOSS will not drop the stream, it's something else, could be the stream itself that is faulty. You can try increasing the network stream buffer size in Settings->Playback->Misc to see if it helps. Apart from that, there's nothing else that can be done from RadioBOSS's side.
