Hello
I am using Radioboss 6.0.6.2.
Since I moved Radioboss on a new computer I cannot add some intro, mix, crossfade point. If I add a point It doesn't stay after I closed the window.
Do you know this issue?
How did you make a move to a new computer, is it a fresh installation or you have restored data from a backup? Does it show any error messages when you save track parameters?
yes I restored the data from the savings I made from radioboss menu.
I don't have any error messages.
If I apply a mix landmark at the end of the file It doesnt stay if I close the window.
We are using windows 10
If you use APEv2, then for WAV and FLAC files it will write information to the alternative NTFS stream on the disk - not to the tag like for other file formats. If you don't use NTFS on the disk where the music files are stored, or it's a network drive, then storage will not work. In this case, you can use the SQLite option instead.
