Jingles not playing at programmed time
Mixnetwork
Hi There
I have a problem with my jingles. I programmed them to play 4 times in 1 hour, see screenshot.
Now he plays a jingle at 2 minutes, but at 15, 30, 45 minutes he puts him in the playlist but does not play it, I think he he puts it to the end of the playlist, but he should play the jingle after the running track.
Is there a way to programm it so that he puts a jingle direct after a running track?
You should disable the "If there are scheduled tracks, put it to the queue" option, this will make it insert the jingle right after the playing track.
