Altec
Hi Dmitry !
Some column sorting doesn't work properly :
Intro : Sorting by intro isn't correct because if thing the sorting is based on the intro lenght from the beginning of the song and not from the start point.
Outro : Same problem, the values are not correctly sorted.
File Type : Sorting by File Type is not working
Mix : Sorting by mix doesn't work
Start : Sorting by start point doesn't work
End : Same
Tags : I Never understand the sorting by tags working
Another problem, there is no option to adjust column widths automatically, or reset them.
Kind Regards
Altec
End : Same
Kind Regards
Altec
