Music Library use by multiple clients
JeanXeb
Hi Djsoft,
Following the switch to Radioboss 6.
I can no longer find the way to work in on our databases in workgroup.
Indeed we are working with XML but it does not seem to exist anymore.
The music library module only sees the databases on the machine where the studio is present.
But the employees of the station work from their machine.
Do you have a solution for me ?
Cordialy
I just set up the MySQL database, it works perfectly on the studio side.
I then have on the same machine opened radioboss in another session. Configure the MySQL link. It works I see the data (oddly in gray) on the other hand the database gives me an error. "Internal audio manager error 2"?
The PFL is correctly configured.
Do you have a solution?
The grey text in the tracks list means that it was unable to load tag information. Error code 2 means that the files can't be accessed. I suppose the problem is that the files are not available on the second computer using the path specified (\\Vm03\nas...) - you need to ensure the folder is available on the second computer as well.
Hi guys! What is the correct way to migrate and configure a Mysql db from a tag db (that we are currently using)?
