stokemusic
since installing the Beta version 6.3 the right channel turns itself off after about 30 minutes. Is this a known bug?
I was 3 hrs on Air without any problem Beta 6.3.0.1since installing the Beta version 6.3 the right channel turns itself off after about 30 minutes. Is this a known bug?
This is a known issue, that happens on some computers. We'll fix it in one of the next updates.I just updated from Beta 6.3.0.0 to 6.3.0.1 and the problem with the right speaker going off is still there. Has anyone else encountered this problem with the new Beta version? Can anyone shed some light on this?
People are writing to my station complaining of only hearing sound from one speaker, it does seem like the issue should be addressed as soon as possible.This is a known issue, that happens on some computers. We'll fix it in one of the next updates.
Just to let you know that the FX tab shows "ReplayGain: +12.9 dB" but my gain is set to 0dB and I can't see anywhere in the settings a way to lower this; the sound is distorted because of it. The Playback is set to Main (on Air) to the internal soundcard (Realtek) this has been the case for years without any problem. This "gain" message appears after re-starting RadioBoss and then disappears after a few minutes. It's very strange, could this be connected with the problem of the right channel turning itself off?This is a known issue, that happens on some computers. We'll fix it in one of the next updates.
This is the ReplayGain tag, it's applied during playback - in addition to the Gain slider. You can disable it in Settings->Playback->Miscellaneous, set Replay Gain to Off.Just to let you know that the FX tab shows "ReplayGain: +12.9 dB" but my gain is set to 0dB and I can't see anywhere in the settings a way to lower this; the sound is distorted because of it.
Yes replay gain is off. I'm still getting the right channel cut off after a few hours, I then have to re-start RB and it works again for another few hours. There have been two updates since I last came across this problem and there's been no fix for it.This is the ReplayGain tag, it's applied during playback - in addition to the Gain slider. You can disable it in Settings->Playback->Miscellaneous, set Replay Gain to Off.
Please try the latest RadioBOSS 6.3.0.2 it should be fixed there: https://www.djsoft.net/community/threads/radioboss-6-3-beta.11183/Yes replay gain is off. I'm still getting the right channel cut off after a few hours, I then have to re-start RB and it works again for another few hours. There have been two updates since I last came across this problem and there's been no fix for it.
I'm afraid to say that it's not fixed, I installed the latest update 6.3.0.3 a few days ago and the only change is that it happens less often, sometimes it goes almost 24 hours without a problem, other times it happens after a few hours.Please try the latest RadioBOSS 6.3.0.2 it should be fixed there: https://www.djsoft.net/community/threads/radioboss-6-3-beta.11183/
To confirm, do you use a 64 bit version, and you have equalizer enabled?I'm afraid to say that it's not fixed, I installed the latest update 6.3.0.3 a few days ago and the only change is that it happens less often, sometimes it goes almost 24 hours without a problem, other times it happens after a few hours.
Yes I use the 64 bit version, and yes I do have equalizer enabled, should I change to the 32 bit version and/or disable the equalizer?To confirm, do you use a 64 bit version, and you have equalizer enabled?
Yes, either of those solutions should work.Yes I use the 64 bit version, and yes I do have equalizer enabled, should I change to the 32 bit version and/or disable the equalizer?
