rotation
alec66
hi,
after several years of radioboss use still experiencing problems with rotation:
-around 5000 songs on rotation splitted into 6 categories
-have songs not played since march/april
-no repeat rules are quite soft
attached some priority rules
thanks for support
Please ensure that you use the latest RadioBOSS 6.1.x.
Playlist Generator uses random number generator to select tracks with equal distribution, when you use priorities it will change the probabilities of the tracks in accordance with the rules you define, but it still won't guarantee you that some track that was not playing for a long time, will play. It's like roulette ball can land 10+ times in a row on "black", and it doesn't violate the probability theory and is perfectly possible.
6.1.2.1 version here payed upgrade;
pls can you check if such settings are correct or something that I can improve?
could be nice is someone with similar number of tracks on DB can share settings working properly
thanks
Your settings are fine. You can try increasing the priority for tracks that didn't play for some time, from 10 to 30, or more.
