I would be great if you guys added "peak listeners" in the "broadcasting statistics" for "total listeneres".
I can track the highest amount of listeners per stream, but it does not record that for total listeners, where it adds the current listeners from all streams. All my streams are the same stations, so would be nice if i knew what the highest peak of listeners were for all streams put together. If I add the listeners peak from each server it would not be accurate since those peaks probably were reached at different times, and not at the same period.
