Trigger restart
patrick.de-bruyn
patrick.de-bruyn said:
A restart RadioBOSS option would be fine iff possible ( See Picture )
Sometimes you have to restart after making changes
You can trigger a restart from the Settings window: open it, click "Advanced options" button, click OK, then click OK in the settings window, it will prompt a restart.
I´v tryed that, it dousnt work
Just a command like restart Radioboss would already help
I followed the arrows in the picture and nothing happens, there is no restart
Maybe its a good idea to make a restart radioboss in the upper left corner at File, on top of the Exit
I don't see how this is useful. When a restart is really required, it will prompt for it. You can still try to trigger it using the settings window, e.g. change "Additional storage information" and then set it back to the original value.
not sure why restarting RB would be needed other than just quit the program and restart it, takes a few seconds
or you can shift-control-escape in windows and end the task, then re-run the program
