bobby, nelson c
E-mails with access data were sent to you.
How to connect:
1. click Start->All Programs->Accessories->Remote Desktop Connection, in the "Computer" field enter radioboss.fm.
2. click Options (at the bottom left), select Local Resources tab, in the "Local devices and resources" select "More..." and check "Drives" to share your drives with the remote system. This is needed so you can copy music, jingles and other things there. (see the picture attached)
3. Click Connect button, enter login and password. Some Windows versions have a bug: if you copy-paste password it won't connect. Just enter the username and password manually if you face this issue.
