Duplicates Check
It will be great a tool in Music Library to check if there are duplicates (physically).
Thanks !
Thanks !
It already checks if one file is added more than once. Or did you mean finding duplicated across different folders?
Thanks !
I mean finding duplicates and remove them from library and location too. Only if it is possible.
While this is possible, I don't think this should be added to the software - finding identical files is easy, but if e.g. files have different playcount value, those are not identical anymore. Also there can be one song that is saved under different bitrates. This becomes really complex if done right, and I think there are products whose sole feature is searching duplicate music files.
