Mark played tracks in playlist as not played
Arild
Hi
In settings, style, it is possible to select different background color and font for played tracks in the playlist.
Is there a possibility to reverse it.
Is it possible to mark played as not played tracks in playlist
We often use the same playing list as a template
Then it would have been nice if the tracks were not marked as played with  a color that shows played tracks
regards
Arild
Currently it's only possible using the resetplayedstate scheduler command (you can create an event or cart wall item with this command). When you launch it, all tracks in the playlist will become "non-played".
