DJSoft.Net
English Deutsch Espanol Русский
RadioBOSS
Read MoreDownloadBuy Now
Author Topic: RadioBOSS Reviews  (Read 30569 times)
  • Administrator
    • http://www.djsoft.net
Re: RadioBOSS Reviews
« Reply #45 on: March 23, 2017, 05:11:07 PM »
Thank you for the good words!
Matei ᵇᵒˢˢ₋ᵘˢᵉʳ
  • Goodness - the only sign of superiority!
« Reply #46 on: June 14, 2017, 10:24:26 AM »
The most powerful radio automation program.
I love RadioBOSS!
Version 5.6.0.6 is amazing!
Matei - math teacher
Înseamnă să te iubești foarte puțin dacă urăști pe cineva, dar înseamnă să urăști pe toată lumea dacă nu te iubești decât pe tine!
  • Administrator
« Reply #47 on: June 15, 2017, 07:22:55 AM »
Matei, thank you!
Pablo
« Reply #48 on: February 15, 2018, 12:17:43 PM »
Hola, saludos cordiales, he usado varios automatizadores radiales, ahora por un  tiempo he probado Radioboss y me he dado cuenta que es un excelente Soft. el cual tiene y reúne todo lo que puedas necesitar para un buen desempeño en tu radio emisora, es fácil de programar y seguro en su funcionamiento, estoy muy contento de ser parte de aquellos que están probando la versión Beta, recomiendo este Soft. a todo el que está buscando algo profesional y sencillo de usar, felicitaciones !!
  • Administrator
« Reply #49 on: February 15, 2018, 02:14:19 PM »
Thank you for the review!
WKOM
« Reply #50 on: December 06, 2018, 04:26:08 AM »
We have been using RadioBoss and RadioBoss Cloud now for 2 Terrestrial FM Stations and 1 Am Station for almost a year now (Dec 2018) without any major issues! We use smaller additional software's and do everything through and with RadioBoss Cloyd. From Billing, Playlist Creation, "live remotes" and so much more! Our costs are down 90%!! Thank you RadioBoss / DJSoft!!
WKOM 101.7 FM ~ WKRM 103.7 Fm ~ TriStar Radio
  • Administrator
« Reply #51 on: December 06, 2018, 01:29:42 PM »
WKOM, thank you for the review!
southernfm
« Reply #52 on: January 04, 2019, 04:06:43 AM »
88.3 Southern FM was formerly using a different playout software but found it to have technical issues, such as locking up MP3 files, and playing 2 files at the same time when programs switched over from one studio to the other. The learning curve was steep and scheduling required an hour to produce a schedule to last the following 6 weeks.
Looking around, I found RadioBOSS and demonstrated it to our administration team, with a particular focus on its API capabilities, as the previous playout software had none at all.
There was one slight adjustment we needed for it to be perfect for our needs, and after discussing with the developer - we received an updated version 16 hours later. Unprecedented response time, we couldn't throw our money at RadioBOSS fast enough.
We tested it for awhile and released it in March 2017 and have been using it since then. The changeover from our previous software to RadioBOSS was one of the smoothest transitions we've ever had at the station.
While we could operate with older versions of RadioBOSS, we're happy to pay for updates to newer versions, to keep supporting the development of RadioBOSS.
Cameron
88.3 Southern FM
southernfm.com.au
  • Administrator
« Reply #53 on: January 08, 2019, 06:42:46 AM »
Thank you very much for the review and for supporting our work!
