D djsoft Well-known member Staff member May 26, 2023 #41 Joschi said: we need a total of 6 installations of RadioBOSS on 4 devices. ... How many licenses do we need? Click to expand... 4 licenses.
lughsan Active member Mar 4, 2024 #42 After updating RB, is it possible to go back to the previous version? I have version 6.3.3.0.
D djsoft Well-known member Staff member Mar 5, 2024 #43 lughsan said: After updating RB, is it possible to go back to the previous version? I have version 6.3.3.0. Click to expand... What version you want to install?
lughsan Active member Mar 5, 2024 #44 djsoft said: What version you want to install? Click to expand... I think I explained myself wrong, I mean what happens with the license. If I update RB from version 6.3.3.0. at 7.0 Can the license no longer be used in version 6.3.3.0?
D djsoft Well-known member Staff member Mar 6, 2024 #45 lughsan said: If I update RB from version 6.3.3.0. at 7.0 Can the license no longer be used in version 6.3.3.0? Click to expand... Yes of course. The license for a newer versions allows using any previous version as well.
lughsan Active member Mar 25, 2024 #46 I still have doubts about the number of RB installations. What is the maximum number of installations on different computers from 1 single location and 1 modem? for example: connected to 1 modem. Can a license be used on 5 or 10 different computers?
D djsoft Well-known member Staff member Mar 25, 2024 #47 lughsan said: Can a license be used on 5 or 10 different computers? Click to expand... Single license allows three installations, typically: Main on air Backup Training/testing If you need more installations, please consider purchasing more licenses.
D djsoft Well-known member Staff member Mar 26, 2024 #49 lughsan said: Is it possible to buy 1 license that works on 6 computers? Click to expand... Fir this, two licenses will be needed.
