doubts about the protection of musical repetition
How does the system work when adding subfolders?
For example:
I have the main folder:
"Rock"
subfolders are:
"jazz" 15 songs
"blues" 15 songs
"country" 15 songs
In this situation, how does RB select music in random mode and in order?
RadioBOSS doesn't care about folder structure, it only checks the specific parameters of a track, e.g. Artist, or Title - depending on what repeat protection rules you have configured.
@lughsan I have this enabled in and the playlist has files up to 3 deep in subdirectories of the main directory I have this working as it depends on the playlist content, but my playlists are under 4,000 files. I am not sure what criteria it uses for random play maybe Beats Per Minute (BPM) as my best guess, if its available to it. You would need Dimitri to inform you.
Would it be possible to create a music classification by (BPM)?
which will then add the song closest to the (BMP) of the currently streaming song.
