If you don't use the Voice Track feature (that is, voice tracks are as regular music tracks) then they will start playing at Mix point.I configured my tracks without an outro point but the mixpoint would be perfect to start my voice tracks.
Is it possible to configure this without redoing the entire library?
I'm afraid not. You can create a script that will utilize readtag/writetag API commands to make such modifcation.No way to mass edit the tracks to match the mix point with the outro point?
Hi, I think it's possible with SQLlite but I'm a little stuck on the SQL query.I'm afraid not. You can create a script that will utilize readtag/writetag API commands to make such modifcation.
API: https://manual.djsoft.net/radioboss/en/remote_controlapi.htm to m
With sqllite, copying/pasting the mix point column into the outro point column and then reimporting the database seems to work.I'm afraid not. You can create a script that will utilize readtag/writetag API commands to make such modifcation.
It calculates the start time to make the voice track end when Intro ends. In one of the future updates we'll add an option to control the position of the voice track.But the voice track does not start at the outro point of the previous song but just before the intro point of the next song. An idea ?
yes thank you, the best would be for the voice track to start at the outro point and finish at the intro point of the next song. if the voice track is long then calculate a silence between the songs to achieve good timingIt calculates the start time to make the voice track end when Intro ends. In one of the future updates we'll add an option to control the position of the voice track.
This is what the new option will allow to do.yes thank you, the best would be for the voice track to start at the outro point and finish at the intro point of the next song. if the voice track is long then calculate a silence between the songs to achieve good timing
