Add command
StefanoM
Good morning , you can add this command.
Thank you
Stefano
You can enable the Shuffle mode for the playlist (the button under the playlist). In shuffle mode it does not repeat tracks until the whole playlist is played.
Running first time in order and then shuffled looks like a very specific task to me... I'm not sure what is the use case for it.
