Ads scheduler bugs
tomimatko
It's not a big mistake, but it looks ugly. This is the case in all styles.
The highlighting is still dark blue, so you can't see the selected item properly. In other styles, there is no highlighting at all.
Looks like the problem here is cause by using the "classic" Windows style. It's not really supported and it's dropped completely in the latest Windows versions. Enabling runtime themes should fix this.
Yes, you're right. We are using Windows 7, and that's where the issue occurs, while everything works fine on Windows 10.
