Hello support team.
I run since several weeks 2 to 3 Radioboss Playouts in parallel on a Windows Server 2012 R2. Hosting on a Dell 24 Core Server. Some RB always crashes 1 to 3 times a day. I saw one live in a freeze (volume Peak meter), then after around 10 seconds, the supervisor thread kills and restarted. Ok.
After restart, the channel with activated Equilizer comes in Mono - left channel only.
Also it took a lot of effort, the "Repeat Protection" for my Tracklist doesn't work anymore. I have more than 3000 maxi titles in rotation. For 15 days. And with a7 days protection I get a song after 2 hours or after one day. I can see the last 4 playouts in the mouseover, protection is not working anymore. But it is activated.
One RB doesn't use output streaming, only for test stability and repeat protection. It is a standard installation. Only Tracklist. This is stabile. Never had a crash. But this setup was only to compare. The other RB use Trasklist, Repeat protection, every 10 minutes a trailer (DAB Test Ensemble) and send 2 FLAC output streams.
Crashing is in the winnt.dll. So, difficult to know the real reasoun. Maybe the flac coder. I set another one with maybe mp3 or aac.
Ok, to sum. After a c crash there is a different restart with different initializing. Thats my thought. If I close the damaged RB and start it new, everything is fine with repeat protection. Up to the next crash restart.
