Bugs in 4.5.6
RBS
Hi
Can you check the track tool/track properties window.
I can't play back my audio tracks, when I open th ewindow to edit, seems to be a new bug.
Regards
What error message it says? Can you please send one of the tracks you edit (original version will be better) which becomes corrupted after changes? To support@djsoft.net
It does not give an error message, the track tool window opens as normal but when I play a file no sound!
If I double click from the music library it plays just fine  in RadioBOSS play, but not in the track tool.
Also track tool audio file time should normally say 0:00 start time and for example 3:40 end time.
Now it's saying - 0:00 start time , and when i click on the play button in the start part...it does not play!!
I thought it corrupts audio files... Glad it's not :)
Since RadioBOSS 4.5.6, Track Tool uses "prelisten" output as specified in RadioBOSS's Playback settings. Previously it used system default device, but it wasn't a good solution...
