Collumns for kbps
patrick.de-bruyn
One of my group members asked if it would be possible to make a column for the kbps in the playlist and in the database,
and I would like to have in the database below that you could also search for the BeatsPerMinute when you enter them there.
Reading "kbps" will increase the time required when creating a library, so RadioBOSS does not do it. It only reads it when a track is played.
patrick.de-bruyn
Yes, but is it really needed? There's BPM search in the player Search area - it seems more fit there if you need to quickly find/insert tracks with specific BPM.
if I want to search with the tag Dance but only those with 128 bpm is not possible in the search
If you had it in the database as shown above this would be no problem to find there the matching songs
