Generato Pro "less played track"
Radio Sange
I am very satisfied with RadioBoss.
I use Generator Pro for scheduling my playlists and I am more than satisfied with the result, the only thing I can not do is to rotate the less played tracks.
What rules should I use in Generator Pro?
OK .. RISOLTO
Yes, the Priorities should be used for this. You should probably use AVG instead of MIN to select tracks that play less.
