How to xml Prayer times
medesan
Hello, as it is known, adhan is read on the radio during prayer times in Muslim countries. Prayer times change every day. How can we add prayer times to scheduled programs with xml instead of updating azan times every day?
Hi, i just saw this request. We are interested in the same topic, i hope we can find a solution for the call of Prayer time which goes 5 times a day, total of 1825 around the year. We have all the times on an excel sheet. Just to make it more clear, the prayer time changes every day but it stays the same for the same day each year. For example the prayer times for 1/1/2024 are the same for 1/1/2025.
What i tried to do is to make the events Manually (1825event) then choose the option to repeat every year.☺️
I think a solution for this will attract hundreds of Islamic radios to use this software.
You can create multiple events for each week day with different start times.
I tried to find some details about how to make the multiple event actions in user manual but there wasn't much. Can you guide me where to find some more details about it. Thank you.
It's likely that you can reduce the number of events, if you need. Events in RadioBOSS have "Repeat every" feature that allows periodically repeating the same event. If you need different start times, it's also supported using the "Multiple start times" option - it allows defining different start times/days for a single event (in the event window select "Hours", press "..." and switch to Multiple start times to use this feature.
It's described here: https://manual.djsoft.net/radioboss/en/scheduler_options.htm
You need to press the "multiple start times" button at the top and define event's actions.
