Linking two Tracklist playlist tabs
Chaz
How can I have my Weekday Tracklist (in the player - Tab #1) go to my Weekend Tracklist (in the player - Tab #2) at 5PM Friday and return to my Weekday Tracklist on Sunday at 6PM? Seems simple, but I'm dazed and confused. Thanks in advance.
Be sure your tab names are unique. RadioBoss will allow duplicates.
For example, if your Tab #1 was named Weekday and your Tab #2 was named Weekend then:
You can set up two scheduler events.
Set the first new scheduler event as follows:
Playlist/track filename or command to: playlist Weekday
Time to: 6:00 pm
Weekdays to: Checked
Su to: Checked
Mo Tu We Th Fr Sa to: Not Checked
Set the second new scheduler event as follows:
Playlist/track filename or command to: playlist Weekend
Time to: 5:00 pm
Fr to: Checked
Su Mo Tu We Th Sa to: Not Checked
I'm not sure if Maximum time to wait in queue should be checked for both events and min to around 5. It seems to enque and then activate after the currently playing track finishes when checked or unchecked. The activated playlist may start a couple of minutes after the hour depending upon the length of the currently playing track at execution.
So, I was close but no cigar. Thanks, I will try this and see what happens. Many thanks for a positive path forward.
UPDATE: Thank you. You solved my issue and the player worked switching TrackList Playlists on my computer today. I've set up the scheduling on my RadioBoss program on my server. Your knowledge was invaluable.
