Mono feature!
meatball1986
Hello!I use the 4.0.2.428 version of Radio Boss and at the Web Radio Station that i joined the shoutcast server is at 64kbps 44100 khz Mono!!!How can i switch from stereo to mono??Thanks in advance!
Hello!
It's not possible yet. I added it to request list and this will be added in the RadioBOSS 4.5. Thanks.
Thank you!One more question about that.If i use the  stereo tools plugin which has a preset 'Web Radio(Mono)" does it fix this issue?
This won't help, RadioBOSS will still send data in stereo format to the encoder. The only way to fix this (without waiting for update of RadioBOSS) is to broadcast using some third party program like EdCast and select "Mono" there.
I use RadioBoss with Edcast for about a month now and sometimes when it goes from one song to the next one, it crashes and i can't figure out why.Do you have any suggestion to solve this problem or is there any other programm compatible with RadioBoss to broadcast with?
What crashes, RadioBOSS or Edcast? Id it's EdCast you can try using RadioCaster (it's in beta state now, but should work): http://www.djsoft.net/smf/index.php/topic,848.0.html
RadioBOSS itself contains broadcasting feature - better to use it.
If you need mono broadcasting, please wait until we release RadioBOSS 4.5 - it offers new features to change sample rate and channels for broadcasting.
