Music Library with picture
Currently we do not plan on adding this. How this would be useful?
Music Library is designed to index tracks and to perform bulk operations.
We could use the Music Library to create playlists. We do this now in ITunes and then drag and drop in into the different Playlists in the player. See printscreen
Music Library is not a good tool for creating playlists. It doesn't even allow you to change the locations of the tracks. You can use additional playlist tabs in the main window to edit playlists.
We use now the playlist tabs to edit playlists, what I am missing there is, that ones the song is in a playlist, the play counter and last playd date is not uptating. (in the music library this datas get upated)
It reads track information when playlist is first loaded, and only updates it before and during the playback. We'll see how updating the data in the playlist can be improved. Thank you for pointing out this issue.
