Need help?
Ron
I wanna clear the play list every time I load a M3u play list I make. How do I do that can I? Also do I check clear play list on the schedule page?
If you load it using scheduled event, then check the "Clear playlist" checkbox.
If you load it manually, then simply click the Open button.
Thanks alot ill retry the scheduler more than 2 items was not working right for me for some reason.
