new radio caster not connecting
wireradio
i updated my radio caster but now its not connecting it says err 40 just says connecting not conected
can i go back or can it be fixed
Network 40 is network timeout error. It doesn't look like a bug in RadioCaster. You should check if your antivirus/firewall blocks the connection.
You can download the previous version if you like:
http://dl.djsoft.net/RadioCaster_setup_2.2.0.0.exe
funny i went back to the old one and its connected again i wonder what the problem was there must have been a small change that affected it working
If you have antivirus installed, probably it has rule which allows old version to connect, while it prevents connections from the new version.
