Option to not insert in playlist, instead of automatic grey out.
Bjorn
I have created an event which runs multiple makelibrary commands and then a play command via API. See below:
When a http:// action is in a multiple action event, and you run the event, all the steps appear in the playlist.
But if I remove the network API command, the event just fires, and don't appear in the playlist.
So to fix this, maybe it's worth having another option in "Insert Position" to block playlist insert instead of greying out the option?
Events that load in playlist:
Events that don't load in palylist:
The scheduler checks what actions an event has. If there are no playable items, only commands, it will execute the events in the background. If there are playable items, entire event will be inserted into the playlist.
