Playlist Generator Pro error message
Bensisko
Hello There,
I'm asking for help with an error message that appears in Playlist Generator pro, when I activate the Generate function, the progress bar freezes and I get this error that you see in the picture, I press the ok button the generation starts again and after a very short time it freezes again. The playlist generation operation ends regularly.
What can this error message be due to?
My pc has windows 1
Thank you
Translated with DeepL
Thank you, we'll check why this error box can appear. A quick test did not confirm this bug.
If you use any sort of software that changes taskbar or start menu behavior, this can be the cause.
hello, perfect, hoping that in the next version it is solved, it is very annoying to have to close the window every time, otherwise the playlist generation is blocked.
It will be fixed for sure, at least the messagebox will be removed if we are unable to find the cause.
