radiodungog
Hello Dmitry,
We are using Playlist Generator Pro to create 7 static playlists each with 12 hours of music content to get us through the day. We name the static playlists: Monday, Tuesday, Wednesday .... Sunday.
Our master source playlists of content are typically called:
50s, 60s, 70s, 80s, 90s, 2000s ... and Easy, Gold and Soft Rock.
Each source playlist has been shuffled.
Some source playlists have plenty of songs in them - a few of them do not have many songs - but certainly enough to give us a no repeat format for the whole week.
We use the Generate "In order" setting in PGPro.
We have the "Start Position" ... "Advance on each generation" box ticked.
We are noticing that some songs are repeated frequently during the week - typically 3 or 4 or 5 times - and our listeners are telling us that - and we have verified this to be correct from the station logs.
Can you explain briefly the maths involved with the Generate "In order" and "Advance on each generation" functions ? I can see that the "Start Position" number change after each generation.
Are we doing this the correct way ?
A while ago you and I spoke about having a feature to generate a large playlist (in this case 7 x 12 = 84 hours) and then having the PGPro automatically cut it up into many separate playlists so that the "do not repeat song" rules would work over the whole range of the playlists generated.
Thanks, Jamie C.
Thanks, Jamie C.
