Popup "The application seems to be frozen" even though it works ok
suiyonari
I purchased RadioCaster and have been using it successfully for about 2 years now (without updating, if it ain't broke don't update it).
I use it in a multiple-instance manner, by having multiple copies of the executable environment. Most of the time all copies work well without an issue, but sometimes they continue working well except that after a few seconds of starting up, the application will detect a false positive for a "frozen" trigger and cause the popup to appear in reference to at least one instance, and although it doesn't affect the stream, it is enough of an annoyance i wished would be possible to disable.
My question then is, is it possible to disable it, since it serves no apparent purpose.
Thank you for your time.
The freeze detection thing checks if the UI is responsive - it's considered unresponsive if it's stuck for 30 or more seconds. As you use a 2-year old version, I recommend you updating it to the latest one, a lot of things were fixed/improved since then.
