Preset groups in Scheduler wizard
tomimatko
I suggest in the Scheduler wizard > Generate a playlist > Select template - that they be sorted in Preset groups, as the Presets in Playlist Generator Pro.
So it's better organized and easier to find if they a lot of preset.
Thank you for the suggestion, we'll consider implementing it in the next update.
