Problem generating playlists
Greetings
I am using 4.5. 0.733.
I want to be able to generate a new playlist every hour. I tried using the scheduler to generate a playlist using Playlist Generator Pro (Scheduler Wizard > Perfrom Action > Generate Playlist, then the name of my template.
Unfortunately, at the scheduled time, it simply reloads the exact same playlist that appeared last hour.
I appreciate your help. Kind regards :)
Seems it failed to create a new playlist and old file wasn't overwritten. You should check the template you're using (by pressing the Generate button several times and checking if report contains some error messages).
Note that Playlist Generator Pro is still in testing state (alpha)... So it's very possible that it doesn't work as expected sometimes.
